[SOLVED] Auto-Translate in Chinese (Simplified vs. Traditional)
  • [X ] Checked the logs and have uploaded a log file and provided a link because I found something suspicious there. Please do not post the log file in the topic because very often something important is missing.
  • [X ] Bug report
Chinese Traditional (zh-TN) fields get a Chinese Simplified (zh-CN) translation
zh-TN should be translated into Chinese Traditional and not Chinese Simplified.
  1. Write a few words in English
  2. Auto translate it to Chinese Simplified (zh-CN) and to Chinese Traditional (zh-TN)
  3. Both translations will be identical
  4. Try to do the same things in Google Translate and compares - results in Chinese Traditional (zh-TN) will look different.
Maybe the translation API considers Chinese as Chinese Simplified only?
  • [ ] Self hosted with docker
  • [X ] Cloud version
  • [X ] Chrome (desktop)
  • [X ] Safari (desktop)
Hi, I use deepl and google (in this order). It seems that deepl only supports chinese language in general. So I will have to use google for this case.
Will be fixed soon.
@Sebastian Thank you!
I think this has been fixed, can you check it?
Not sure it works. I think it still shows in Chinese Simplified (zh-CN) rather than in Traditional (zh-TW).
Have you pressed translate again? And cleared all values before?
OK, I think I know what didn’t work.
I think the languages are flipped - zh-TN is showing simplified translation while zh-CN shows the traditional translation (should be the opposite)
Do you have an English term that i can test?
the word “phone”:
simplified - 电话
traditional - 電話
Also, not sure if you changed anything, but when erasing the languages fields in existing items (not new ones) - it still shows just the simplified version. Now it shows in both fields the simplified version for both existing and new.
btw: zh-TW is not traditional, it is taiwanese. I do not know if this makes a difference.
But I don’t understand what you mean with your last paragraph.
I know, but it’s common that Taiwanese refers to Chinese Traditional, while in Mainland China it’s Simplified.
If I create a new item/post and type the word “phone” the translation will be in Simplified for both languages.
Okay, but neither google translate nor deepl seem to support zh-TW, so it is always converted to “zh”.
I think I have to add zh-TN to the language list.
I can also make a mapping from zh-TW -> zh-TN if that makes sense.
Did you do the mapping? Because now it works as expected:
zh-CN = Simplified
zh-TW = Traditional
Yes, I did … thanks for your feedback
Great! Thank you for the prompt support!
