[SOLVED] AI dialog box won't work as expected
I can see AI button over the input control, but it’s not working as expected. “Use” button not set AI generated to textarea or textbox. “Close” button won’t close the dialog and in textarea shows [event object]
“Use” button should set AI generated text to textare or textbox and close button will close the dialog box.
It is already solved a while ago, but I havent had the resources to deploy it yet, because the current release also contains a few change to the text indexing.
Ohh! If possible, just know when we can expect deployment.
This topic was automatically closed after 46 hours. New replies are no longer allowed.
