Hello Sebastian,
I was trying to send emails using the SMTP integration service with SendGrid (They have one option to use SMTP).
After configuring the Host, Port, User and Password Notifo skips the sending of the email.
It skips because there was some error or is something else? I wanted to create an integration to use their API but wanted to try it first with SMTP.
Thanks for your help.
