Here’s my use case…
I have a locations page which is its own schema. Nested in that schema is a “type-location” schema that can handle multiple locations. These are store locations, FYI.
I have a slug field and am attempting to fill it via create and update scripts on the “type-location” schema when editing the locations page content. The slug field on “locations” (the locations page) works, while the nested component field for “type-location” does not work. No slug is created for it.
I have the script in the create/update of the nested component type instead of referencing it from the parent. “locations” -> “type-locations[]”
Do I just have the script wrong or is this a bug?
Thanks for your help!
