Schema with array inside array
Hi guys,
We are working on Github version and need to implement schema model that supports array inside array, 3 levels at least.
The customer do not want to use the schema reference feature because in this scenario there’s no content reuse.
Below an example of the desired schema format.
    blocks: [
        questions: [
            screens: [
                visualizations: [
Do you have suggestions about implementation?
Thanks in advance.
I would consider to use a json field and write a custom editor. I think it could be very complicated otherwise to manage it.
