Sorry this has turned into a bit of an essay with quite a few different points in, I’d really appreciate you taking the time to read it but can understand if you want to hold off and enjoy your Friday or want me to break it down into more granular support tickets?
We are currently a bit cavalier about our deployments so we are looking to polish them up a bit to make them safer rather than waiting for something to go wrong. We are currently on v6.9.0 but are looking to move to v7.x in the near future.
There are a couple of bits I have been reading:
https://docs.squidex.io/02-documentation/concepts/migrations
I just wanted to check if what I am proposing is viable or dangerously wrong.
Current situation (Squidex v6.x)
We are in a load balanced environment resulting in two instances of Squidex with clustering enabled.
When we release we perform the following steps:
Take Leg 1 out of the balance
Deploy changes to Leg 1
Test Leg 1
Assuming everything is OK with Leg 1 put Leg 1 back in balance at same time as taking Leg 2 out of the balance
Deploy changes to Leg 2
Assuming everything is OK with Leg 2 put Leg 2 back in balance
Deploying changes can include the following:
A change to the version or configuration of Squidex
A change to the structure of a Squidex App (e.g. schema modifications) (Note: we only do these changes during Leg 2 deployment as it can apparently cause issues with clustering otherwise)
A change to the contents of a Squidex App (Note: these are usually dependent on schema changes so also are only made during Leg 2 deployment)
Currently both legs share a database and we are not setting readonly mode to true, hence being a bit nervous about our current deployments.
Is there somewhere we can check the Version in the Migration MongoDB collection before we deploy a new Squidex release so we know if migrations will need to happen or not? For example we are currently on v6.9.0; would there be any migrations (i.e. is it safe to just release with our current setup) if we were to upgrade to v6.14.0?
Readonly mode
I was wondering if you think this is only needed when we are changing the version of Squidex or if it is also advised when you are potentially changing the structure of a schema? As they currently share a database if I start testing Leg 1 with changes that amended a schema and someone is editing content for the old version of that schema in Leg 2 might that cause problems?
Is there a reason for having to set this before the application starts up or would having an API endpoint to toggle readonly mode be viable? (if so I will raise a feature request)
Checking migrations have completed
I was looking at the Migration collection in MongoDB and am assuming that we would ideally be checking to see if any migrations are still taking place (i.e. IsLocked: true) before we disable readonly mode and continue with the release?
Backup of the database
This is also something we are not doing as part of release process (don’t worry we do have a regular backup process in place for disaster recovery) and I am struggling to see a way of automating it, but as it is best achieved with mongodump it is a seperate issue for us to get sorted as it is not directly related to Squidex.
7.x
We will now need a worker node to coordinate changes between our two load balanced instances.
My understanding is that you should only ever have one Worker node and you always need a Worker node active even if you just have one Squidex instance.
I believe this means during normal operation we should have:
Leg 1: Squidex Instance 1 (Active) & Squidex Worker Instance 1 (Active)
Leg 2: Squidex Instance 2 (Active) & Squidex Worker Instance 2 (Inactive)
So I think our release process would need a few extra steps:
Enable Squidex Worker Instance 2 when Leg 1 is taken out of the balance
Ensure Squidex Worker Instance 1 only targets Squidex Instance 1 and Squidex Worker Instance 2 only targets Squidex Instance 2
When putting both Legs back into the balance we need to disable Squidex Worker Instance 2 and ensure Squidex Worker Instance 1 targets both targets Squidex Instance 1 and Squidex Instance 2
I am not at all confident in what I have just laid out so would greatly appreciate any feedback or elaboration around it!
CONTENTS__OPTIMIZEFORSELFHOSTING
We are self hosting with currently just the one app per Squidex instance with tens of thousands pieces of content in various schemas so this sounds like something we should be using but I am unsure of the advantages and disadvantages; is the only way to check this to create a testing instance with it enabled and see how much bigger the database is and how it performs or is there a rough way of estimating how much it could impact speed of reading and writing?
