- [X] Bug report
When the docker compose file (with a little tweak that I’ll explain later) is started, the login page shows this error:
(sorry for the Spanish language, but the error I think that is trying to access to the HTTPS version: https://127.0.0.1/identity-server/connect...)
The login page is working so that you can access to Squidex.
- Download the https://github.com/Squidex/squidex-hosting/blob/master/docker-compose/docker-compose-noproxy.yml file.
- Create a
.envfile with the minimal configuration:
SQUIDEX_DOMAIN=127.0.0.1
SQUIDEX_ADMINEMAIL=<user email>
SQUIDEX_ADMINPASSWORD=<user password>
- Change in the Docker file this line: https://github.com/Squidex/squidex-hosting/blob/master/docker-compose/docker-compose-noproxy.yml#L4 getting rid of Mongo version, because with 4 version Squidex 5 is not working.
- Run the Docker compose with:
docker-compose up
- [X] Self hosted with docker
Version: 5
- [X] Chrome (desktop)
I have read that there is (or there was) another parameter that can be configured URLS__ENFORCEHTTPS but I have tried specifying it in the .env fila and in the Dockerfile, in the environment section, as false, but it’s not working.
