- [x] Bug report
Local backend build crashes if frontend application not running. WebpackMiddleware does not handle the exception of line 39 failing.
Should give you helpful message to run the frontend node application and to ensure port 3000 is not used by anything else.
- [x] Local build from Rider IDE
Version: 5.7
- [ ] Chrome (desktop)
- [x] Brave
Attached picture of default behaviour vs improved behaviour: https://imgur.com/a/B3PMJcH
I’ll be happy to send pull request if you require thanks. I understand it isn’t mission critical but thought I would suggest. Thanks.
