- [x ] Bug report
I’m unable to run squidex in docker on my local.
Tried https://github.com/Squidex/squidex-docker/blob/master/standalone/docker-compose-noproxy.yml In this file changed https://${SQUIDEX_DOMAIN}/ to http://${SQUIDEX_DOMAIN}/ as it gave me error in popup because of incorrect url.
Squidex run fine but i can’ login as administrator. Login popup hangs or redirects to login again after providing correct credentials. Tried to setup squidex on IIS. And have the same issue over http. When I added https binding login worked fine. So it is not possible to use squidex over https?
as i understood this will not work for local environment as letsencrypt can’t generate certificates for local environments.
this file worked fine for me for a while. but now i started experiencing the following issue with certificate:
What is the best way to run squidex locally in docker?
Have possibility to login in squidex.
Run docker-compose files on local environment.
- [x ] Self hosted with docker
Version: [5]
- [ x] Chrome (desktop)
