- Bug report
- Performance issue
The tool set on the rich text editor is now showing as a vertical block rather than a horizontal block above the text field. This has only just appears after a hard reset on my primary browser.
Tool block should be horizonatal block rather than a vertical block
- Self hosted with docker
- Self hosted with IIS
- [X
] Cloud version
- Chrome (desktop)
- Chrome (Android)
- Chrome (iOS)
- Firefox
- Safari (desktop)
- Safari (iOS)
- IE
- Edge
