Hi @Sebastian I want the support regarding the retriving the multiple reference schema
Below I am sharing the output of rest api which contains reference schema i have to convert that to graphql
In the above section there is one array containing single object in that one Content property contains 3 reference schema
When we pass all that 3 schemas as a parameter in the postman than i get array containig 3 objects
Sharing the screenshot of rest api which contains 3 schema id of content as a parameter
In the above screenshot there are 3 objects inside an array and inside every object there is content property and that content property contains 3 different schemas which contains our data
Remember that for 3 object content contains 3 different schemas
Remaining screenshot of 2 different objects
Below screenshot of graphql query i travel till the array of 3 objects but further i am not able
Expected behavior!
- [ ] Chrome (desktop)
