- [ ] Used code blocks with ``` to format my code examples like JSON or logs properly.
when I try to apply this filter,
I get the following error:
Request Method:PUT
Status Code:404
other requests(GET, POST, DELETE) work correctly
web config:
I would like the filter to work
- [x] Self hosted with IIS
Version: 7.6.1.0
- [x] Chrome (desktop)
