Request documentation to deploy in AWS (self-hosting)
  • [ ] Checked the logs and have provided the logs if I found something suspicious there
  • [ ] Bug report
  • [X ] Documentation issue or request
  • [X ] Self hosted with docker
  • [ ] Chrome (desktop)
I have my local Squidex environment working, and I’m ready to move it to a self-hosted environment in AWS.
Looking through the forums post, it seem like many users are using AWS, but there is not documentation about what consideration should I take to accomplish that.
Thanks for the support, any help is appreciated.
Do you use docker or just a VM?
I’m using docker.
In AWS I want to use Fargate if posible.
Have you just tried the documentation about docker?
