- Read the following guideline: https://docs.squidex.io/01-getting-started/installation/troubleshooting-and-support. I understand that my support request might get deleted if I do not follow the guideline.
- [X ] Bug report
- Performance issue
When creating a content item that has an image asset (via API), the POST request works as expected; however, I changed the mongodb deployment to run as a replicaset (single node), and the squidex API request times out. Interestingly enough, if I comment out the image ID from being created (or updated), the API request works as expected, but the minute I have an asset ID (which is valid and works via front-end to assign to content item) within the content request, the API returns a 500 error and the below error shows within the logs. Is there something I need to change for squidex to work with the replicaset?
development-squidex-1 | "message": "A timeout occurred after 30000ms selecting a server using CompositeServerSelector{ Selectors = ReadPreferenceServerSelector{ ReadPreference = { Mode : Secondary } }, LatencyLimitingServerSelector{ AllowedLatencyRange = 00:00:00.0150000 }, OperationsCountServerSelector }. Client view of cluster state is { ClusterId : \u00221\u0022, ConnectionMode : \u0022ReplicaSet\u0022, Type : \u0022ReplicaSet\u0022, State : \u0022Connected\u0022, Servers : [{ ServerId: \u0022{ ClusterId : 1, EndPoint : \u0022Unspecified/host.docker.internal:27017\u0022 }\u0022, EndPoint: \u0022Unspecified/host.docker.internal:27017\u0022, ReasonChanged: \u0022Heartbeat\u0022, State: \u0022Connected\u0022, ServerVersion: 6.0.0, TopologyVersion: { \u0022processId\u0022 : ObjectId(\u0022658f348512e5c37a483e20d6\u0022), \u0022counter\u0022 : NumberLong(6) }, Type: \u0022ReplicaSetPrimary\u0022, WireVersionRange: \u0022[0, 17]\u0022, ElectionId: \u00227fffffff0000000000000005\u0022, LastHeartbeatTimestamp: \u00222023-12-29T21:18:12.4997162Z\u0022, LastUpdateTimestamp: \u00222023-12-29T21:18:12.4997193Z\u0022 }] }."
Here is my docker-compose for the relica setup:
mongo:
image: mongo
command: ["--replSet", "rs0", "--bind_ip_all", "--port", "27017"]
ports:
- 27017:27017
extra_hosts:
- "host.docker.internal:host-gateway"
healthcheck:
test: echo "try { rs.status() } catch (err) { rs.initiate({_id:'rs0',members:[{_id:0,host:'host.docker.internal:27017'}]}) }" | mongosh --port 27017 --quiet
interval: 5s
timeout: 30s
# start_period: 0s
# start_interval: 1s
retries: 30
volumes:
- ./data/mongodb:/data/db
- "mongo_config:/data/configdb"
Associating a content item with an existing asset ID works regardless of replicaset mongodb setup or not.
Use the above docker-compose configuration as a back-end data store for squidex, and create a content item that has an image asset field. Create that content item via API with an asset ID of an already uploaded image, and you’ll see the issue.
- [ X] Self hosted with docker
- Self hosted with IIS
- Cloud version
Version: 7.0
- Chrome (desktop)
- Chrome (Android)
- Chrome (iOS)
- Firefox
- Safari (desktop)
- Safari (iOS)
- IE
- Edge
