- [X] Bug report
Trying to set the SchemaId for on the type ReferencesFieldPropertiesDto does not exist. Instead a SchemaIds field (ICollection) is available. However populating this field does not update the Reference properties for the schemaids. I can see the API in the browser uses the same endpoint however this sends the property “schemaId” instead of SchemaIds.
The API should allow you to update \ change the SchemaId for a reference field.
