I have created 3 schema classes: Models, Grades, and Accessories
In the schema, Grades have a reference field to Models
Using C# and the squidex nuget library, what do I define the reference property as?
public sealed class ModelData
{[JsonConverter(typeof(InvariantConverter))] public string Name { get; set; }}
public sealed class GradeData
{[JsonConverter(typeof(InvariantConverter))] public **xxxx** ModelID { get; set; } [JsonConverter(typeof(InvariantConverter))] public string Name { get; set; }}
What is the type for xxxx above?
Also, I want to create a many-to-many relationship between Grades and Accessories, so I created an additional Schema table called GradeAccessories with a reference to Grades and a reference to Accessories. Is there any way to represent this relationship automatically in the model and populate the referential data automatically when I call GetAsync on either one of the Grade or Accessories classes?
