- [ X] Used code blocks with ``` to format my code examples like JSON or logs properly.
- [ X] Documentation issue or request
Question
Hi Sebastian, how are you?
I’m not sure if the following is possible but I hope you can help me:
I want to be able to reference to a field inside the current schema item
let’s say I have the following schema with their values
- Field1: Value1
- Field2: [Value20, Value21, Value23]
- Field3: Field2.Value21, Value3;
As you can see, I referenced to a value of Field2 in the value of Field3.
Is this possible or not? Because I want to add data to a combination of multiple fields.
Kind regards,
Martijn
