Hello I am trying out Squidex as a possible solution for a simple company branded website for simple content creation. I want to set it up with React.js. I have recreated your React example project and changed the config for my app. I havent had success getting my auth token working. I am able to get it working on Postman though. I am not sure where I am going wrong and the request error is very generic.
- recreated a react clientside for Squidex from your react sample app here:
https://github.com/Squidex/squidex-samples/tree/master/jscript/react/sample-blog
- [x] Bug report
I can get the request token when I POST through postman to my Squidex cloud app. But I keep getting a client request error when I try to make the same request through React.
Return an auth token on React client
Here is my fetchBearerToken method. Comparing my postman POST and my React POST, I noticed the content-type was different. So I added the application/x-www-form-urlencoded header to the request. With or without that header I get the same result.
export async function fetchBearerToken() {
// Check if we have already a bearer token in local store.
let token = getBearerToken();
if (token) {
return token;
const body = new FormData();
body.set('grant_type', 'client_credentials');
body.set('client_id', CONFIG.clientId);
body.set('client_secret', CONFIG.clientSecret);
body.set('scope', 'squidex-api');
// Get the bearer token. Ensure that we use a client id with readonly permissions.
const response = await fetch(buildUrl('identity-server/connect/token'), {
method: 'POST',
headers: {'Content-Type': 'application/x-www-form-urlencoded'},
body });
if (!response.ok) {
throw new Error(`Failed to retrieve token, got ${response.statusText}`);
const json = await response.json();
token = json.access_token;
// Cache the bearer token in the local store.
setBearerToken(token);
return token;
Here are the Request headers from my React App:
Accept /
|Accept-Encoding|gzip, deflate, br|
|Accept-Language|en-US,en;q=0.5|
|Connection|keep-alive|
|Content-Length|616|
|Content-Type|application/x-www-form-urlencoded|
|Host|cloud.squidex.io|
|Origin|http://localhost:3000|
|Referer|http://localhost:3000/|
|TE|Trailers|
|User-Agent|Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:81.0) Gecko/20100101 Firefox/81.0|
Here are the Response headers from my React App:
access-control-allow-origin *
|cache-control|no-store, no-cache, max-age=0|
|cf-cache-status|DYNAMIC|
|cf-ray|5e5570c36c4d2fde-ORD|
|cf-request-id|05e944ce1d00002fde930d5000000001|
|content-type|application/json; charset=UTF-8|
|date|Tue, 20 Oct 2020 20:20:37 GMT|
|expect-ct|max-age=604800, report-uri="https://report-uri.cloudflare.com/cdn-cgi/beacon/expect-ct"|
|nel|{"report_to":"cf-nel","max_age":604800}|
|pragma|no-cache|
|report-to|{"endpoints":[{"url":"https:\/\/a.nel.cloudflare.com\/report?lkg-colo=14&lkg-time=1603225237"}],"group":"cf-nel","max_age":604800}|
|server|cloudflare|
|set-cookie|__cfduid=dd4b05e0fdb9008432d4adcd486a1eb9f1603225237; expires=Thu, 19-Nov-20 20:20:37 GMT; path=/; domain=.squidex.io; HttpOnly; SameSite=Lax; Secure|
|X-Firefox-Spdy|h2|
- [x] Cloud version
- [x] Chrome (desktop)
- [x] Firefox
