How is this not a valid query? It worked in the browser Graphiql
I think it should be:
query {
pages: queryPagesContents {
id
Thanks for the reply.
This still doesn’t work, I get the error “Either Ids or Schedule range must be defined.”
Which version do you use? Local or cloud?
This works for me in the cloud:
I can also not reproduce your problem with the latest version.
I’m using cloud version at the moment, it works fine on the integrated graphiql.
But when I use the same query in postman it doesn’t work. Really scratching my head on this.
It works for me now.
My error was not putting “/graphql” at the end of the url haha
Thanks for the help, I’ve been stuck at this for longer then I want to admit.
