QueryContext Explanation
Hello!
I am attempting to change some of the headers for requests through the QueryContext in the Client Library. I cannot seem to figure out how to pass through IsFlatten or Languages through to my requests.
For example:
public async Task GetAsync(string id, QueryContext context = null)
Guard.NotNullOrEmpty(id, nameof(id));
        var response = await RequestAsync(HttpMethod.Get, BuildContentUrl($"{id}/"), context: context);
        var check = await response.Content.ReadAsStringAsync();
        return await response.Content.ReadAsJsonAsync<TEntity>();
QueryContext is passed in as a parameter, but how is that object actually filled? I know I am missing something dumb here…
Thank you,
Blake
QueryContext is probably the wrong name from the client perspective.
You can create a context like this:
var ctx = QueryContext.Default.Flatten();
And then just pass it in as an parameter.
Understood, that worked thank you.
