- Bug report
- Performance issue
Ends in errore and remains “pending”
Upsert to Elasticsearch
We are having problems updating elasticsearch from squidex.
The initial rule searches for the document and deletes it before trying to upsert the new document, if the document isn’t found it if throws and error:
"2025-06-24T07:13:20Z: Failed with error
Request failed to execute. Call: Status code 404 from: DELETE /sardegna-statistiche-dev-index/_doc/01020714-4227-4a60-9f75-e68a56c3ca62"
If the document is starting from a new I end up with this error:
“Serialization and deserialization of ‘System.IntPtr’ instances is not supported. Path: $.ApiCall.ConnectionConfiguration.BootstrapLock.AvailableWaitHandle.Handle.”
have you come across this error?
we had previously passed from 7.6.1 → 7.15 then onwards after testing to 7.20
the version of elasticsearch is: 8.13.4
I tried via a curl to see if there is a problem with elasticsearch and had no problems
- Self hosted with docker
- Self hosted with IIS
- Cloud version
Version: 7.20
- Chrome (desktop)
- Chrome (Android)
- Chrome (iOS)
- Firefox
- Safari (desktop)
- Safari (iOS)
- IE
- Edge
