Hi, I have a question regarding assets and whether there is an alternative way to change the structure for where assets are stored.
Currently, we have a custom setup that works by linking to multiple internal assets, with each asset located under its respective route. Here are some examples:
/product-catalog
“downloads/product-catalog/someasset.pdf”
“/downloads/product-catalog/someasset.pdf”
/manuals
“/downloads/manual//someasset.pdf”
/doc
“/downloads/doc//someasset.pdf”
And so on…
All link names are static and must remain the same. We are now looking at migrating this site and its content to Squidex, but I am struggling to figure out how to achieve this.
At first, I considered using redirects, but Squidex’s asset management makes it difficult because all assets are placed in the same folder:
perl
Kopiera
Redigera
http:///api/assets/{app}/{idOrSlug}/{*more}
Is there any way to modify the asset structure? For example, if I have a schema named “downloads,” could all assets uploaded under this schema be placed under api/assets/downloads?
We have a self hosted squidex using the docker image
