[OUTDATED] Vertical images are corrupted after cropping
  • [x] Bug report
We uploaded vertical image with width=“4912” height=“7360”
When we apply cropping it gets corrupted:
?width=1280&height=650&mode=crop
?width=1280&height=650&mode=cropupsize
At the same time resizing works well: ?width=1280&height=650&mode=max
The image should change the aspect ratio without losing image quality.
Upload high resolution image to Media library and try to resize it with crop or cropupsize mode.
  • [x] Self hosted with docker
Version: 4.2.0
This is already fixed in newer versions.
Thank you, Sebastian, for your quick reply, we will definitely upgrade to the latest version.
/Andrew
The fix is that image orientation will be fixed when uploaded. So you might need to upload it again.
