Order of embedded components
  • [X ] Bug report
I have a components field where I can embed other schemas as an array. In squidex you can modify the order of the embedded schemas. But when I retrieve the contents with the c# lib, the order is ignored.
I want to order to that I retrieve with the lib, to be the same as the order in Squidex.
  • [X ] Self hosted with docker
  • [] Cloud version
Squidex.Clienlibrary version 15.1.0
I don’t believe that tbh. There is nothing that would touch that component field.
oo wauw…you know what I did wrong…
I completely ignored the order myself when accessing the extra information…
