OData filter by slug
I am trying to limit request data items with filtering the reqest like this.
https://cloud.squidex.io/api/content/appname/posts?$filter=data/slug/iv eq ${route.params.slug}
but it returns all of the items. Any ideas?
Have you tried single quotes for your value?
no difference - using single quotes or template literals gives the same response - returning all items. And no special chars in slug
EDIT - I had an error in the query but now it returns 400
0: “Syntax error at position 20 in ‘data/slug/iv eq how-to-setup-a-private-nuget-feed-in-azure-devops-pipelines’.”
message: “Query $filter clause not valid.”
so I guess it’s the dash issue
I mean
$filter=data/slug/iv eq 'how-to-setup-a-private-nuget-feed-in-azure-devops-pipelines'
this seems to be working…thank you. Added single quotes around variable and it works!
once again squidex support is perfect! good job!
