- Bug report
- Performance issue
Install from helm chart:
helm upgrade --install squidex squidex/squidex7 --wait --namespace=mca-test -f values.yaml
Pod not started:
squidex-mongodb-replicaset-0 0/1 Init:2/3
kubectl describe pod squidex-mongodb-replicaset-0 -n mca-test
Events:
Type Reason Age From Message
Normal Scheduled 4m16s default-scheduler Successfully assigned mca-test/squidex-mongodb-replicaset-0 to k8s-w3-dmz
Normal Pulled 4m15s kubelet Container image "busybox:1.29.3" already present on machine
Normal Created 4m15s kubelet Created container copy-config
Normal Started 4m15s kubelet Started container copy-config
Normal Pulled 4m15s kubelet Container image "unguiculus/mongodb-install:0.7" already present on machine
Normal Created 4m15s kubelet Created container install
Normal Started 4m15s kubelet Started container install
Normal Pulled 4m14s kubelet Container image "mongo:3.6" already present on machine
Normal Created 4m14s kubelet Created container bootstrap
Normal Started 4m14s kubelet Started container bootstrap
kubectl describe Statefulset squidex-mongodb-replicaset -n mca-test
Events:
Normal SuccessfulCreate 7m59s (x2 over 97m) statefulset-controller create Pod squidex-mongodb-replicaset-0 in StatefulSet squidex-mongodb-replicaset successful
Warning RecreatingFailedPod 7m59s (x2 over 7m59s) statefulset-controller StatefulSet mca-test/squidex-mongodb-replicaset is recreating failed Pod squidex-mongodb-replicaset-0
Warning FailedDelete 7m59s (x2 over 7m59s) statefulset-controller delete Pod squidex-mongodb-replicaset-0 in StatefulSet squidex-mongodb-replicaset failed error: pods "squidex-mongodb-replicaset-0" not found
kubectl logs squidex-mongodb-replicaset-0 -n mca-test
Defaulted container "mongodb-replicaset" out of: mongodb-replicaset, copy-config (init), install (init), bootstrap (init)
Error from server (BadRequest): container "mongodb-replicaset" in pod "squidex-mongodb-replicaset-0" is waiting to start: PodInitializing
- Self hosted with docker
- Self hosted with IIS
- Cloud version
Kubernetes (baremetal, no direct connection to the internet)
Kubernetes v1.27.5
- Chrome (desktop)
- Chrome (Android)
- Chrome (iOS)
- Firefox
- Safari (desktop)
- Safari (iOS)
- IE
- Edge
