I’m trying to delete and bulk delete squidex content items with a non-guid Identity/SquidexId using Squidex Client library version 10.2.0 (was a given try on the latest version 10.7.0 also).
When calling squidexClient.BulkUpdateAsync(bulkUpdate) with BulkUpdateJobs of type
new BulkUpdateJob()
Id = squidexId,
Schema = schemaName,
Type = BulkUpdateType.Delete,
Permanent = true
Where squidexId is a string in format
“author-12345”, “author-12345–some-fragment-text”
template: {ContentType}-{id} [–{content.FragmentText}].
After BulkUpdateAsync() executed - BulkResult items have status 500 error, without any error message.
Same happens for
squidexClient.DeleteAsync(squidexId, new ContentDeleteOptions { Permanent = isPermanent }).
Content items with non-guid SquidexId successfully deleted, as same as items that have Guid as SquidexId.
- Create content items in Squidex using BulkMode with setting a SquidexId/Identity as non-guid value, in format {ContentType}-{id} [–{content.FragmentText}], example “author-12345–some-fragment-text”.
Example:
new BulkUpdateJob
Data = contentLink,
Schema = SchemaNames.ContentLinks,
Type = BulkUpdateType.Create,
Status = “Draft”
Id = $"{idPrefix}-{contentLink.DomainId}–{contentLink.FragmentId}"
- Try to delete them using SquidexClient Library in bulk and non-bulk mode, targeting with squidexId
- See error status 500 returns in BulkResult, and Squidex logs has some additional info (attached in the end)
Version: 7.3.0
- Browser is not used
Squidex Logs for an error case.
errormessage
Failed to execute content bulk job with index 3727 of type Delete.exception.message
Requested version -1, but found 0.exception.type
Squidex.Infrastructure.States.InconsistentStateException
exception.stackTrace
at Squidex.Infrastructure.States.Persistence1.WriteEventsAsync(IReadOnlyList1 events, CancellationToken ct) in C:\src\src\Squidex.Infrastructure\States\Persistence.cs:line 234
at Squidex.Infrastructure.Commands.DomainObject1.DeleteCoreAsync[TCommand](TCommand command, Func3 handler, CancellationToken ct) in C:\src\src\Squidex.Infrastructure\Commands\DomainObject.cs:line 207
at Squidex.Infrastructure.Commands.DomainObject1.DeletePermanentAsync[TCommand](TCommand command, Func3 handler, CancellationToken ct) in C:\src\src\Squidex.Infrastructure\Commands\DomainObject.Execute.cs:line 156
at Squidex.Infrastructure.Commands.CachingDomainObjectMiddleware3.ExecuteCommandAsync(T executable, TCommand command, CancellationToken ct) in C:\src\src\Squidex.Infrastructure\Commands\CachingDomainObjectMiddleware.cs:line 38 at Squidex.Infrastructure.Commands.AggregateCommandMiddleware2.ExecuteCommandAsync(CommandContext context, CancellationToken ct) in C:\src\src\Squidex.Infrastructure\Commands\AggregateCommandMiddleware.cs:line 38
at Squidex.Infrastructure.Commands.AggregateCommandMiddleware2.HandleAsync(CommandContext context, NextDelegate next, CancellationToken ct) in C:\src\src\Squidex.Infrastructure\Commands\AggregateCommandMiddleware.cs:line 26 at Squidex.Domain.Apps.Entities.Contents.DomainObject.ContentsBulkUpdateCommandMiddleware.HandleAsync(CommandContext context, NextDelegate next, CancellationToken ct) in C:\src\src\Squidex.Domain.Apps.Entities\Contents\DomainObject\ContentsBulkUpdateCommandMiddleware.cs:line 136 at Squidex.Infrastructure.Commands.AggregateCommandMiddleware2.HandleAsync(CommandContext context, NextDelegate next, CancellationToken ct) in C:\src\src\Squidex.Infrastructure\Commands\AggregateCommandMiddleware.cs:line 26
at Squidex.Domain.Apps.Entities.Comments.DomainObject.CommentsCommandMiddleware.HandleAsync(CommandContext context, NextDelegate next, CancellationToken ct) in C:\src\src\Squidex.Domain.Apps.Entities\Comments\DomainObject\CommentsCommandMiddleware.cs:line 38
at Squidex.Infrastructure.Commands.AggregateCommandMiddleware2.HandleAsync(CommandContext context, NextDelegate next, CancellationToken ct) in C:\src\src\Squidex.Infrastructure\Commands\AggregateCommandMiddleware.cs:line 26 at Squidex.Domain.Apps.Entities.Assets.DomainObject.AssetCommandMiddleware.HandleAsync(CommandContext context, NextDelegate next, CancellationToken ct) in C:\src\src\Squidex.Domain.Apps.Entities\Assets\DomainObject\AssetCommandMiddleware.cs:line 66 at Squidex.Domain.Apps.Entities.Assets.DomainObject.AssetsBulkUpdateCommandMiddleware.HandleAsync(CommandContext context, NextDelegate next, CancellationToken ct) in C:\src\src\Squidex.Domain.Apps.Entities\Assets\DomainObject\AssetsBulkUpdateCommandMiddleware.cs:line 130 at Squidex.Infrastructure.Commands.AggregateCommandMiddleware2.HandleAsync(CommandContext context, NextDelegate next, CancellationToken ct) in C:\src\src\Squidex.Infrastructure\Commands\AggregateCommandMiddleware.cs:line 26
at Squidex.Domain.Apps.Entities.Apps.DomainObject.AppCommandMiddleware.HandleAsync(CommandContext context, NextDelegate next, CancellationToken ct) in C:\src\src\Squidex.Domain.Apps.Entities\Apps\DomainObject\AppCommandMiddleware.cs:line 40
at Squidex.Domain.Apps.Entities.Schemas.Indexes.SchemasIndex.HandleAsync(CommandContext context, NextDelegate next, CancellationToken ct) in C:\src\src\Squidex.Domain.Apps.Entities\Schemas\Indexes\SchemasIndex.cs:line 152
at Squidex.Domain.Apps.Entities.Apps.Indexes.AppsIndex.HandleAsync(CommandContext context, NextDelegate next, CancellationToken ct) in C:\src\src\Squidex.Domain.Apps.Entities\Apps\Indexes\AppsIndex.cs:line 189
at Squidex.Domain.Apps.Entities.Invitation.InviteUserCommandMiddleware.HandleAsync(CommandContext context, NextDelegate next, CancellationToken ct) in C:\src\src\Squidex.Domain.Apps.Entities\Invitation\InviteUserCommandMiddleware.cs:line 68
at Squidex.Domain.Apps.Entities.Apps.Plans.RestrictAppsCommandMiddleware.HandleAsync(CommandContext context, NextDelegate next, CancellationToken ct) in C:\src\src\Squidex.Domain.Apps.Entities\Apps\Plans\RestrictAppsCommandMiddleware.cs:line 63
at Squidex.Domain.Apps.Entities.Apps.AlwaysCreateClientCommandMiddleware.HandleAsync(CommandContext context, NextDelegate next, CancellationToken ct) in C:\src\src\Squidex.Domain.Apps.Entities\Apps\AlwaysCreateClientCommandMiddleware.cs:line 38
at Squidex.Domain.Apps.Entities.Apps.Templates.TemplateCommandMiddleware.HandleAsync(CommandContext context, NextDelegate next, CancellationToken ct) in C:\src\src\Squidex.Domain.Apps.Entities\Apps\Templates\TemplateCommandMiddleware.cs:line 55
at Squidex.Infrastructure.Commands.CustomCommandMiddlewareRunner.HandleAsync(CommandContext context, NextDelegate next, CancellationToken ct) in C:\src\src\Squidex.Infrastructure\Commands\CustomCommandMiddlewareRunner.cs:line 27
at Squidex.Web.CommandMiddlewares.ETagCommandMiddleware.HandleAsync(CommandContext context, NextDelegate next, CancellationToken ct) in C:\src\src\Squidex.Web\CommandMiddlewares\ETagCommandMiddleware.cs:line 61
at Squidex.Infrastructure.Commands.InMemoryCommandBus.PublishAsync(ICommand command, CancellationToken ct) in C:\src\src\Squidex.Infrastructure\Commands\InMemoryCommandBus.cs:line 43
at Squidex.Domain.Apps.Entities.Contents.DomainObject.ContentsBulkUpdateCommandMiddleware.ExecuteCommandAsync(BulkTaskCommand bulkCommand) in C:\src\src\Squidex.Domain.Apps.Entities\Contents\DomainObject\ContentsBulkUpdateCommandMiddleware.cs:line 158
