[NOT_REPRODUCIBLE] Data restoration not working
  • [x] Bug report
I have created app backup from one machine & restore on another squidex instance. Both is done successfully but, when I try to update content having reference field it gives error “Data update fails please reload page”
It should be work.
  • [ ] Self hosted with docker
  • [x] Self hosted with IIS
  • [x] Chrome (desktop)
I either need the exception from the logs or your backup. Preferable both. You also have not specified the used version.
Hi @Sebastian,
I backup from squidex 5.4.0 and try to restore in same version, also tried to restore with 5.6.0.
Both are not working.
Please refer the backup from drive.
https://drive.google.com/file/d/1P_zRWH3nn2Cf-5wqbPSlXhnbazZcbOcn/view?usp=sharing
I have hosted squidex in iis. I don’t know how to refer the log file.
Let me know if required.
Thanks
Rakesh Kanani
Btw: Infos abot logging are in the docs: https://docs.squidex.io/01-getting-started/installation/install-windows-iis#where-can-i-see-the-logs
Hi @Sebastian,
Thanks for the guide for log.
I have checked the log but nothing is there related to error.
refer the log file as below.
https://drive.google.com/file/d/1lmeOR8AOoHss2a77c8pz3EzGdZUg4KDn/view?usp=sharing
Regards
Rakesh Kanani
Hi @Sebastian,
Any update on this issue?
Thanks
Rakesh Kanani
The log file is not complete.
@Sebastian
Refer full log from here.
https://drive.google.com/file/d/159WcjzsDZGpja4Unry7tdsltdvbjGIfL/view?usp=sharing
You can download the backfile from here.
Regards,
Rakesh Kanani
I cannot reproduce it with the current version. Please try the latest dev version. You probably need to build it yourself when you use IIS.
