We are not able to modify schema by adding/updating fields.
We are getting the below error.
Can you please help out to resolve this.
Thank you.
- [ ] Chrome (desktop)
Please provide all the information from the checkboxes.
This issue is appearing only if I click on “Create and close”. “Create and add field” is working.
Okay, good to know. I will have a look.
I just added the field to your schema and it works for me.
I think I found the issue and will provide a fix tomorrow.
For developers
The problem is the following code as an example:
public class MyTest
public DomainId Calculated
get { return DomainId.Combine(Id0, Id1.Id); }
public DomainId Id0 { get; set; }
public NamedId<DomainId> Id1 { get; set; }
This code can potentially throw an exception in the property Calculated
, when Id0
is null
. Usually it does not happen. When the property is the first property the serializer tries to deserialize them in order.
When JSON.NET deserializes a property it also ready the property. I guess to support deserializing to readonly collection properties. But when the calculated property is the first Id1
is null at this moment and a NullReferenceException
is thrown. There are 2 potential fixes:
- Making the calculated property the last property, which is not possible when
Id1
is defined in a base class.
- Ignoring the calculated property during serialization, which is the correct fix in my opinion anyway, because it safes a few bytes and improves performance.
Sometimes, when a request is received at NodeA, it needs to be forwarded to NodeB and this is when the serialization problem happens. So it is actually totally random.
