- [ x Bug report
When I submit any GraphQL Request through the C# Squidex.ClientLibrary the response is always empty. If I copy the exact same query into the online GraphQL editor the result is populated with the expected data. If the search term is an empty string I, however, get a result.
When utilizing the GraphQlAsync method the same result should be returned as if posted through the online editor.
- Create query, e.G.
{ querySHEMAContents(search:""" + searchTerm + @""", filter:""" + filter + @""") { data: flatData { prop1, prop2, prop3 { id } } } }" - Call GraphQlAsync Method:
var result = await _client.GraphQlAsync(query);
- [ x] Cloud version
