- [ x ] Read the following guideline: https://docs.squidex.io/01-getting-started/installation/troubleshooting-and-support. I understand that my support request might get deleted if I do not follow the guideline.
- [ x ] Documentation issue or request
- [ x ] Self hosted with docker
Version: 5
- [ x ] Chrome (desktop)
I’m evaluating Squidex and got stuck while designing a schema that would work to build a demo. What i’m trying to achieve is to map in Squidex a custom schema and then find a way to map between what Squidex generates into the format I need. The hiccup i got to is that my schema is designed to have an “indefinite” depth.
The custom properties i think i can add them as tags, maybe use tags to indicate which number field is integer or float, but the multi level, i don’t know how to design that.
Any help and ideas on how i could map the following JSON into a Squidex schema? If you look at the “location” section it has child sections 2 levels deep.
"modelSchema": [
"section": "UserInfo",
"category": "none",
"properties": [
"name": "name",
"dataType": "string"
"name": "age",
"dataType": "integer",
"subcategory": "ages"
"name": "address",
"section": "location",
"category": "location",
"properties": [
"name": "officelocation",
"section": "teamInfo",
"category": "team",
"properties": [
"name": "projectcode",
"dataType": "string",
"subcategory": "projectcode"
"section": "teammembers",
"category": "none",
"properties": [
"name": "username",
