I have one general question that we are not clear off, tried searching for concrete answer in documentation but still not sure of the right answer.
Does Squidex support separate mongoDB instance per tenant or we can only achieve multitenancy by separate applications?
No, there is no multi-database support. You have to use separate apps for that. It makes maintenance easier, therefore I decided to go that route.
