Multi-Level Schema Categories
Good Morning.
We’ve started bringing data into our Squidex instance and grouped the schemas into 3 categories.
We’re now bringing in some more data and want to have a separate higher level category.
(something like this)
Has something like this been considered before, or if we implemented it is there a way that would work well with any other planned features?
I feel it may have some overlap with the Taxonomies discussion: Taxonomies for content items
Thanks
Simon
It has nothing to do with taxonomies in my opinion. A simple solution could be to allow paths like “Locations/Data” in the category name and then build the UI.
Hi Sebastian.
I’ve implemented this in our version. Would this be something you may be interested in pulling back into your version?
Thanks
Yes, sounds interesting. Can you make a screenshot?
