Hello,
we would like to move from the PAAS Solution of Squidex to your SAAS solution.
Can you tell me, whom I can send the backup to/how to provide it, so you can migrate it to our Account in your environment?
Thanks.
Hello,
Thanks.
Hi, I am glad to hear that. You can create a backup in your local app and then send me the URL as a PM. I will then test it locally and when everything is fine restore it to the cloud.
Thank you for your response - could you tell me where I can send you a PM?
If you click to my profile picture you should see a PM field.
“Sorry, you cannot send a personal message to that user.”
