- [ x] Read the following guideline: Troubleshooting and Support | Squidex. I understand that my support request might get deleted if I do not follow the guideline.
- [ x] Used code blocks with ``` to format my code examples like JSON or logs properly.
- Bug report
- Performance issue
- [ x ] Documentation issue or request
I’m trying to use the GraphQL API in my C# Blazor app to get content from Squidex, as I have fields with richtext and would prefer to get HTML from Squidex for those fields, which only seems to be possible with GraphQL. I had the basics working with REST, but realising I could not request HTML for the richt text fields made me reconsider.
Modeling each paragraph etc. as an object seemed difficult, so I created the following query in the API explorer:
findFaqPageSingleton {
data: flatData {
title
entries {
question
answer {
html
As I was not successful with creating models for this GraphQL request, I tried to just get a JObject back, like this:
var ctx = QueryContext.Default;
ctx = ctx.WithLanguages(CultureInfo.CurrentUICulture.TwoLetterISOLanguageName);
ctx = ctx.Flatten();
var query = @"
data: flatData {
title
entries {
question
answer {
html
var result = await Client.SharedDynamicContents.GraphQlGetAsync<JObject>(query, context: ctx);
Unfortunately, this always produces an error:
Unhandled exception rendering component: Object serialized to String. JObject instance expected.
System.ArgumentException: Object serialized to String. JObject instance expected.
at Newtonsoft.Json.Linq.JObject.FromObject(Object o, JsonSerializer jsonSerializer)
at Newtonsoft.Json.Linq.JObject.FromObject(Object o)
at Squidex.ClientLibrary.ContentsSharedClient`2.BuildQuery(Object request)
at Squidex.ClientLibrary.ContentsSharedClient`2.GraphQlGetAsync[TResponse](Object request, QueryContext context, CancellationToken ct)
at Cognoscito.Web.Features.Faq.Pages.Index.OnInitializedAsync() in C:\Users\stipps\source\Cognoscito\src\Cognoscito.Web\Features\Faq\Pages\Index.razor.cs:line 34
at Microsoft.AspNetCore.Components.ComponentBase.RunInitAndSetParametersAsync()
Unfortunately, I could not find any guidance or examples on how to use this with the C# ClientLibrary. Other threads in the forum seem to link to a test project on Github which does not exist anymore.
Is there some documentation on how to use the ClientLibrary that I was just not able to find?
I get a JObject instance that contains the data shown in the API explorer when I execute the query.
- [ x ] Self hosted with docker
- Self hosted with IIS
- Cloud version
Version: 7.14.0
- Chrome (desktop)
- Chrome (Android)
- Chrome (iOS)
- Firefox
- Safari (desktop)
- Safari (iOS)
- IE
- [ x ] Edge
The schema of the faq-page:
"previewUrls": {},
"properties": {
"validateOnPublish": false
"scripts": {},
"isPublished": true,
"fieldRules": [],
"fieldsInLists": [],
"fieldsInReferences": [],
"fields": [
"name": "Title",
"properties": {
"isRequired": false,
"isRequiredOnPublish": true,
"isHalfWidth": false,
"fieldType": "String",
"createEnum": false,
"editor": "Input",
"inlineEditable": false,
"isEmbeddable": false,
"isUnique": false,
"minWords": 1,
"contentType": "Unspecified"
"isLocked": false,
"isHidden": false,
"isDisabled": false,
"partitioning": "language"
"name": "Entries",
"properties": {
"isRequiredOnPublish": false,
"fieldType": "Components",
"calculatedDefaultValue": "EmptyArray",
"schemaIds": [
"913149b9-7fb0-45f1-b7e6-349b6a965d31"
"isLocked": false,
"isHidden": false,
"type": "Singleton"
The the faq-entry component:
"previewUrls": {},
"properties": {
"scripts": {},
"fieldRules": [],
"fields": [
"name": "Question",
"properties": {
"editor": "Input",
"isUnique": false,
"isLocked": false,
"isHidden": false,
"partitioning": "invariant"
"name": "Answer",
"properties": {
"fieldType": "RichText"
"isLocked": false,
"isHidden": false,
"type": "Component"
