MongoDB SSL Configuration
I will install Squidex, but MongoDB Cluster and SSL supported are used where I will install it. For this I need to define the pem file. Do I have to make a change on the code side for this? I guess there is a pem file and a password for the file.
Thank you
  • [ ] Self hosted with docker
  • [X] Self hosted with IIS
Version: [5.4]
No, it can be configured via connection strings: https://docs.mongodb.com/manual/reference/connection-string/#urioption.tlsCAFile
