 - [x] Performance issue
I have multiple schema that contains text, numbers and media files. As per the requirement I have to create a copy of the data based on certain conditions. So for that I used to get data from Squidex and write back to Squidex making few modification.
Let suppose I have 3 schema
Schema1
Schema2
Schema3
I first get data from Schema1 based on some filters. So I get list of data
For reference I have using Schema name as model in my code.
Below is the Flow of the code:
List<Squidex1> lstSquidex1=await IContentClient<Squidex1>.GetAsync(filter);
foreach (var squidex1 in lstSquidex1)
      Done changes to data
      await IContentClient<Squidex1>.CreateAsync(squidex1);
      List<Squidex2> lstSquidex2 = await IContentClient<Squidex2>.GetAsync(filter);
      foreach(var sqiodex2 in lstSquidex2)
             await IContentClient<Squidex2>.CreateAsync(squidex2);
             List<Squidex3> lstSquidex2 = await IContentClient<Squidex3>.GetAsync(filter);
             foreach(var squidex 3 in lstSquidex3)
Above is the code flow
In the above process there is a spike in CPU usage and when I checked on Task Manager it is MongoDb that is consuming almost 99% of CPU usage
Can you please help me with the changes I need to do so that CPU usage is reduced.
 - [x] Self hosted with IIS
Squidex Version: 6.7.0
MongoDB Version: 4.0.10 Community
Squidex.ClientLibrary Version: 8.21.0
VM Configuration: 2 Core 4GB RAM
