- [x ] Read the following guideline: https://docs.squidex.io/01-getting-started/installation/troubleshooting-and-support. I understand that my support request might get deleted if I do not follow the guideline.
- [x ] Bug report
After upgrading from 5.4.0 to 5.7.0 no content appears when viewing any schema in the content section. When trying to rebuild consumers (e.g. the TextIndexer5) an error occurs:
MongoDB.Driver.MongoCommandException: Command aggregate failed: Resume of change stream was not possible, as the resume point may no longer be in the oplog…
at MongoDB.Driver.Core.WireProtocol.CommandUsingCommandMessageWireProtocol1.ProcessResponse(ConnectionId connectionId, CommandMessage responseMessage) at MongoDB.Driver.Core.WireProtocol.CommandUsingCommandMessageWireProtocol1.Execute(IConnection connection, CancellationToken cancellationToken)
at MongoDB.Driver.Core.WireProtocol.CommandWireProtocol1.Execute(IConnection connection, CancellationToken cancellationToken) at MongoDB.Driver.Core.Servers.Server.ServerChannel.ExecuteProtocol[TResult](IWireProtocol1 protocol, ICoreSession session, CancellationToken cancellationToken)
at MongoDB.Driver.Core.Servers.Server.ServerChannel.Command[TResult](ICoreSession session, ReadPreference readPreference, DatabaseNamespace databaseNamespace, BsonDocument command, IEnumerable1 commandPayloads, IElementNameValidator commandValidator, BsonDocument additionalOptions, Action1 postWriteAction, CommandResponseHandling responseHandling, IBsonSerializer1 resultSerializer, MessageEncoderSettings messageEncoderSettings, CancellationToken cancellationToken) at MongoDB.Driver.Core.Operations.CommandOperationBase1.ExecuteProtocol(IChannelHandle channel, ICoreSessionHandle session, ReadPreference readPreference, CancellationToken cancellationToken)
at MongoDB.Driver.Core.Operations.ReadCommandOperation1.ExecuteAttempt(RetryableReadContext context, Int32 attempt, Nullable1 transactionNumber, CancellationToken cancellationToken)
at MongoDB.Driver.Core.Operations.RetryableReadOperationExecutor.Execute[TResult](IRetryableReadOperation1 operation, RetryableReadContext context, CancellationToken cancellationToken) at MongoDB.Driver.Core.Operations.ReadCommandOperation1.Execute(RetryableReadContext context, CancellationToken cancellationToken)
at MongoDB.Driver.Core.Operations.AggregateOperation1.Execute(RetryableReadContext context, CancellationToken cancellationToken) at MongoDB.Driver.Core.Operations.ChangeStreamOperation1.Execute(IReadBinding binding, CancellationToken cancellationToken)
at MongoDB.Driver.OperationExecutor.ExecuteReadOperation[TResult](IReadBinding binding, IReadOperation1 operation, CancellationToken cancellationToken) at MongoDB.Driver.MongoCollectionImpl1.ExecuteReadOperation[TResult](IClientSessionHandle session, IReadOperation1 operation, ReadPreference readPreference, CancellationToken cancellationToken) at MongoDB.Driver.MongoCollectionImpl1.ExecuteReadOperation[TResult](IClientSessionHandle session, IReadOperation1 operation, CancellationToken cancellationToken) at MongoDB.Driver.MongoCollectionImpl1.Watch[TResult](IClientSessionHandle session, PipelineDefinition2 pipeline, ChangeStreamOptions options, CancellationToken cancellationToken) at MongoDB.Driver.MongoCollectionImpl1.<>c__DisplayClass66_01.<Watch>b__0(IClientSessionHandle session) at MongoDB.Driver.MongoCollectionImpl1.UsingImplicitSession[TResult](Func2 func, CancellationToken cancellationToken) at MongoDB.Driver.MongoCollectionImpl1.Watch[TResult](PipelineDefinition`2 pipeline, ChangeStreamOptions options, CancellationToken cancellationToken)
at Squidex.Infrastructure.EventSourcing.MongoEventStoreSubscription.QueryCurrentAsync(String streamFilter, StreamPosition lastPosition)
at Squidex.Infrastructure.EventSourcing.MongoEventStoreSubscription.QueryAsync(String streamFilter, String position) in /src/src/Squidex.Infrastructure.MongoDb/EventSourcing/MongoEventStoreSubscription.cs:line 55
Content is available as prior to upgrade and consumers work.
- [x ] Self hosted with other version
Hosted in Cloudfoundry usingdotnetcore buildpack
Version: 5.7.0
- [x ] Chrome (desktop)
I have rolled back the database and performed several times and always results in this issue.
There are no errors in the logs - I only see the above error on the frontend next to a consumer when it is not working
We have mongo DB atlas v4.2.14
