Hi all,
I am trying to write some unit tests against my service which inject the IContentsClient. So I am using Moq to mock IContentsClient. However I am not able to stub or fake the result from GetAsync which is ContentsResult. I need to use the Data property to implement my business logic.
The problem is that Data property in ContentsResult is readonly so I am not able to stub and fake it.
Is there any other ways to write unit tests against GetAsync method using Moq.
Cheers
I am not a Moq user, but I have experience with FakeItEasy. The Data property is readonly but it always has a value, so you can easily do something like this.
class BlogData {
public string Title { get; set; }
class BlogEntity : Content<BlogData> {}
var post = new BlogEntity();
post.Data.Title = "my-title";
var posts = new ContentResults<BlogEntity, BlogData>();
posts.Items.Add(post);
posts.Total = 10;
A.CallTo(() => contentsClient.GetAsync(...))
.Returns(posts);
I don’t see the problem.
Perfect. Thank you so much.
I am very new to Squidex so it is really help me.
Cheers
Hi Sebatien,
Do you know how I can mock GetAllAsync in my unit test.
For example, this is my function
async Task UpdateParentTopicRef(Topic topic)
if (lookUpParentRef.ContainsKey(topic.Data.TopicParentID ?? 0))
var updatedTopicData = new TopicData
TopicId = topic.Data.TopicId,
Name = topic.Data.Name,
Path = topic.Data.Path,
PathSlug = topic.Data.PathSlug,
TopicParentID = topic.Data.TopicParentID,
Parent = new List<string>
lookUpParentRef[topic.Data.TopicParentID]
await topicSquidexClient.UpdateAsync(topic.Id, updatedTopicData);
var migrationResultId = new MigrationResultIds(topic.Data.TopicId.ToString(), topic.Id);
migrationResultIds.Add(migrationResultId);
await topicSquidexClient.GetAllAsync(async topic => { await UpdateParentTopicRef(topic); });
I dont know how to mock the UpdateParentTopicRef
Could you help me?
Many thanks
I am not a moq user (as I said).
But in FakeItEasy it works like this:
A.CallTo(() => contentsClient.GetAllAsync(A<Func<TEntity, Task>>.Ignored, ...))
.Invokes(c =>
var callback = c.GetArgument<Func<TEntity, Task>>(0); // First parameter.
callback(CreateMockContent()).Result; // await is not supported here.
Thanks for suggestions. I have managed to write tests successfully.
