- [ X] Read the following guideline: Troubleshooting and Support | Squidex. I understand that my support request might get deleted if I do not follow the guideline.
- Bug report
- Performance issue
- [ X] Documentation issue or request
I have a .net console app to migrate schemas and schema content from one app to another.
When using the SchemaClient to add a new schema (via PostSchemaAsync method), If a Field is a ‘references’ type and has associated schemaIds listed under validation, they are not getting created with that validation in the target app. Is there an additional flag i need to set or a separate api call i need to make?
Schema Field gets created with associated validation schemaIds in target app
- Self hosted with docker
- [x ] Self hosted with IIS
- Cloud version
- [ x] Chrome (desktop)
- Chrome (Android)
- Chrome (iOS)
- Firefox
- Safari (desktop)
- Safari (iOS)
- IE
- Edge
