- Read the following guideline: Troubleshooting and Support - Squidex. I understand that my support request might get deleted if I do not follow the guideline.
- Bug report
- Performance issue
We have inherited a legacy project, which we have migrated across to our environment, everything is working as it should however the navigation is not. We are upgraded the code to Node 20. when we update the menu in Squidex there is no change on the front end.
We would like to be able to update the menu in squidex and the changes are reflected on the front end.
- Self hosted with docker
- Self hosted with IIS
- Cloud version
- Chrome (desktop)
- Chrome (Android)
- Chrome (iOS)
- Firefox
- Safari (desktop)
- Safari (iOS)
- IE
- Edge
