MathJax- RichText Box HTML
  • [x ] Read the following guideline: Troubleshooting and Support | Squidex. I understand that my support request might get deleted if I do not follow the guideline.
  • [x ] Used code blocks with ``` to format my code examples like JSON or logs properly.
  • [ x] Documentation issue or request
I’m trying to use MathJax in a ich Text box with type HTML, but i get the error message Backend ERROR: Invalid Rich Text
Math Jax HTML saves
Copy and Paste the sample Math Jax HTML into a rich text box
App Name: momath
  • [ x] Cloud version
  • [ x] Chrome (desktop)
Rich Text field has a certain format:
libs/text/Squidex.Text/RichText/Model at main · Squidex/libs · GitHub
it is basically copied from prosemirror: https://prosemirror.net/
If you want to store html content, you need a string field.
