I’m sending a GraphQL query request using the Client Library and GraphQlAsync.<>() .
I can see that the correct data is being returned by the api but I have no idea how to map the result to my entity model. I’ve read the docs and browsed the lIbrary and Squidex backend source. I haven’t slept for a couple of days. Help.
My schema is:
> "properties": {
> "label": "Pages"
> "scripts": {
> "create": "var data = ctx.data;\n \n if (data.title && data.title.iv) {\n data.slug = { iv: slugify(data.title.iv) };\n\n replace(data);\n }",
> "update": "var data = ctx.data;\n \n if (data.title && data.title.iv) {\n data.slug = { iv: slugify(data.title.iv) };\n replace(data);\n }"
> "fieldsInLists": [],
> "fieldsInReferences": [],
> "fields": [
> "name": "title",
> "properties": {
> "isRequired": true,
> "fieldType": "String",
> "editor": "Input",
> "label": "Title"
> "partitioning": "invariant"
> "name": "contentArea",
> "properties": {
> "isRequired": true,
> "fieldType": "References",
> "editor": "Dropdown",
> "maxItems": 1,
> "resolveReference": true,
> "schemaIds": [
> "0e330a52-04f0-49b9-8277-b207016b4c02"
> "label": "Content area",
> "hints": "contentareahint"
> "name": "image",
> "properties": {
> "isRequired": true,
> "fieldType": "Assets",
> "minItems": 1,
> "maxItems": 1,
> "mustBeImage": true,
> "resolveImage": true,
> "label": "Image"
> "name": "body",
> "properties": {
> "editor": "RichText",
> "label": "Body"
> "name": "slug",
> "properties": {
> "isRequired": true,
> "editor": "Input",
> "label": "Slug (Autogenerated)",
> "hints": "Autogenerated slug that can be used to identity the page."
> "isDisabled": true,
> "isPublished": true
My query:
> queryPageContents(filter: "data/slug/iv eq 'indoor-cricket'") {
> id
> flatData {
> title
> slug
> body
> image {
> id
> url
> contentArea {
> id
> flatData {
> name
> basePath
> slug
My entity data model:
> public class PageData
> [JsonProperty(PropertyName = "title")]
> public string Title { get; set; }
> [JsonProperty(PropertyName = "slug")]
> public string Slug { get; set; }
> [JsonProperty(PropertyName = "body")]
> public string Body { get; set; }
> [JsonProperty(PropertyName = "image")]
> public List<string> Image { get; set; }
> [JsonProperty(PropertyName = "contentArea")]
> public List<string> ContentArea { get; set; }
My api client:
> public class ApiClient : IApiClient
> private readonly SquidexClient<Page, PageData> pagesClient;
> public ApiClient(IOptions<AppOptions> appOptions)
> var options = appOptions.Value;
> clientManager =
> new SquidexClientManager(
> options.Url,
> options.AppName,
> options.ClientId,
> options.ClientSecret);
> pagesClient = clientManager.GetClient<Page, PageData>("page");
> public async Task<Page> GetPageAsync(string slug)
> var graphQlQuery = new
> query = @"{
> queryPageContents (filter: ""data/slug/iv eq '" + slug + @"'"") {
> id
> flatData {
> title
> slug
> body
> image {
> id
> url
> contentArea {
> id
> flatData {
> name
> basePath
> slug
> QueryContext ctx = QueryContext.Default.Flatten();
> var result = await pagesClient.GraphQlAsync<JObject>(graphQlQuery, ctx);
Where all the others methods in Squidex.ClientLibrary.SquidexClient return the entity you want, the graphql one doesn’t and I can’t work out how to parse the response.
- [ x] Cloud version
