Login issue Invalid redirect_uri
  • [ ] Checked the logs and have provided uploaded a log file and provided a link because I found something suspicious there.
  • [X] Bug report
  1. Visit homepage BASE_URL
  2. Click on “Login to Squidex” button
  3. Displays the popup with Operation failed Invalid redirect_uri message
  3. Displays the popup with login form with Username & Password
  • [X] Self hosted with docker
Hosted on Azure Kubernetes Service (AKS)
Version: 3.x
  • [X] Chrome (desktop)
  • [X] Safari (desktop)
  • [X] Edge
Environment Variables
URLS__BASEURL: aks-dev-01.southeastasia.cloudapp.azure.com
URLS__ENFORCEHTTPS: true
LOGGING__HUMAN: false
EVENTSTORE__MONGODB__CONFIGURATION: mongodb://squidex-db-0.squidex-db-svc,squidex-db-1.squidex-db-svc:27017/
EVENTSTORE__MONGODB__DATABASE: Squidex2
STORE__MONGODB__CONTENTDATABASE: SquidexContent2
SQUIDEX__PROTOCOL: https
SQUIDEX__FORCE_HTTPS: True
IDENTITY__ADMINEMAIL: <<SOME_ADMIN_EMAIL>>
IDENTITY__ADMINPASSWORD: <<SOME_LONG_ADMIN_PED>>
IDENTITY__GITHUBCLIENT:
IDENTITY__GITHUBSECRET:
IDENTITY__GOOGLECLIENT:
IDENTITY__GOOGLESECRET:
IDENTITY__MICROSOFTCLIENT:
IDENTITY__MICROSOFTSECRET:
Uploading the logs here:
https://ananddevsa.blob.core.windows.net/squidex-logs/logs-from-squidex-in-squidex-app-dcd6c4967-4w626.txt?sp=r&st=2019-06-30T16:00:00Z&se=2019-08-31T15:59:00Z&spr=https&sv=2018-03-28&sig=WEwsoMdye5bb1S1UojlN5%2Bju5H7VtlUrnCaZCdHpzng%3D&sr=b
URLS__BASEURL must be an URL, not a host name, e.g. http://…
Thanks a lot @Sebastian… you saved my day.
Hi Sebastian, I’m getting the same error and the base URL is:
“baseUrl”: “http://localhost:8081”
Thank you!
In the logs it shows the allowed urls and the used urls, please compare them…
Hi, Im sorry for the trouble but stdoutLogEnabled=“true” stdoutLogFile=".\logs\stdout" and I still cant see the logs
Are you using IIS? It should work, I have tested it today. I would also create the folder manually. But this is not my construction site, it is the ASP.NET Core integration for IIS.
Im using IIS, Added the folder, and still no logs. im getting Invalid redirect_uri when trying to log in. no Host name configured through IIS. and its http and not https
I understood that. The base url must be the same url that you use in IIS. If your page is available under http://localhost/squidex then your base url must be exactly this.
Found the issue! Thank you so much!
What was the issue exactly?
