- [x] Bug report
Migration from 5.3.0 to 5.4.0 on the local instance will remove language settings in-app and enable just eng. If I try manually add languages back (in settings) then it looks like content actually stay available.
Migration should not remove language settings.
In 5.3.0 define the app with (non-eng default language - if that matters) and then add a few others (again if that matters). Then migrate to 5.4.0 and at least on my local environment it removes all language settings and keeps just eng.
The language history is even visible in the activity sidebar.
- [x] Self hosted with docker
Version: 5.4.0
