- [x] Bug report
When I try to query using the fulltext filter it return null everytime, I can still filter by Id with successfull results though.
We need to make use of the fulltext filter for queries.
- [x] Self hosted with docker
- [x] Chrome (desktop)
We are running a staging instance which doesnt have this problem, the only difference is that the one that is not working is running under https. Is like the service isn’t even running but I can see it up in the consumers section.
Thanks!
