I created a schema named “productdocs” – and then, since I cannot rename it, I create a new schema called “product-docs”. Squidex API is correct, but the documention doesn’t reflect the correct API name:
Thanks!
Thanks!
Hi, the links on the left side are only descriptive and are converted to pascal case. The UI converts them to uppercase. I will see if I can keep the dashes.
