Hi!
Is there a way to sort items by the last reference? (Items of references-editor component)
Example:
If I select Ottawa
The next time I need to select an item, Ottawa comes first, because it was used recently
Hi!
Example:
If I select Ottawa
I am not exactly sure what you mean…
The items listed in the image are ordered by default by modification date. I would like to sort them by the reference/usage date. Is this possible?
This is not possible, the information is just not available.
