- [X] Documentation issue or request
We’re using the InvariantConverter as an attribute on every property defined in a class to ensure correct serialization of the class and it works as expected. But it makes the code less readable since the attribute is applied across all properties .
Is there a Converter in the Squidex library that can be applied at class level rather than at property level ? This will make the code more readable.
- [X] Self hosted with other version
Version: [5.0.0.0]
- [X] Chrome (desktop)
