I’m testing the Installation screen on Squidex 5.5.0 and I noticed it is sensitive to the format of your baseUrl.
In previous versions of Squidex I have always used a / as the last character.
Now with the new Installation screen, Squidex gives a warning about that the baseUrl's don’t match because in 5.5.0 apparently it needs the baseUrl without the / at the end.
How much of an impact does or can this have?
Does it matter if I have a / or not?
I.e.:
"baseUrl": "https://localhost:5001" vs "baseUrl": "https://localhost:5001/"
Thanks!
